Bell Housing Separate?
mikes86
Car  182 track **** & MX5
Is the bell housing separate on the 182 gearbox? Asking because i have a large hole in mine :(
Thanks Chip-mk1 , don't suppose you have a spare one lying around? :approve:
Also is there any difference between the 1*2 ph1/ph2 gearbox's in regards to the bell housing? For example could i buy a scrap gearbox from any 172/182 and nick the bell housing from it?
Also providing the flywheel is ok, and the gearbox its self isn't damaged, what else could need replacing? Potentially the release bearing & shaft?
Check the clutch while the box is off.
You can use a 172 one, the only difference is that they have a speedo drive hole, but you could plug that.
Sadly the only spare bellhousing I have at the moment has a crack in it.
No need to check the clutch, theres currently shards of it scattered around the engine bay :boring:
