best cutting compound
Hi there,
I have a black/gold 182 ,it has serveral swirls.
Could you tell me which compound works the best with a cutting pad for the porter cable...
Many thanks
  106 GTi
You don't really want to start off the the best cutting compound on a cutting pad.
Start mild and build up to harsh compounds and pads if you need them.
I would look into the Menzerna Final Finish(s) on Polishing pads stepping up to Menzerna Intensive Polish on a cutting pad if needed.
rich,
Which cutting and finishing pads do you use, i have sonus and ccs pads.
I have not tried the megs yet but ive read some good right ups about em.
cheers
jonny
  106 GTi
The Megs Pads seem better suited to Rotary use.
On my own car mostly DAS pads.
Most other jobs Sonus SFX Cutting, polishing and finishing pads, Menzerna Polishing Pads and Lake Country Glazing Pads.
  RenaultSport clio 172 CUP
car lacks 68
Best I have used by far and I 've tried loads.
Follow this with chemical guys spider web.
This combo removed scratches and swirls that nothing else would.
  Skoda Fabia vRS
i use the poorboys ssr range, tried a lot and settled with this, produces the results and is very easy to work with, and a doddle to remove aswell
  106 GTi
The Poorboys are by far the easist to master, the gloss and finish the Menzerna Final Finishes get surpasses that of them though.
