best offset for 2118s
Pearce
Car  172 cup
as above looking in to buying some 2118s but dnt no wat offset wud be best for my ff 182 any help wud be great cheers
If you can get them to fit et38 would be good as it gets you a wider track.
No idea if 182's can take a et38 tho. Ph1 and 2 172's can
surely et 43 would be closer seen as standard is et45
i would go et 38 tho they will fit and shouldnt scub if your no too low
Et38 or et43.
You want the et43 ones, especially as id assume you intend to lower it/ have some camber with fitting these wheels?
I'm running ET37 15x7" rims on my 182 FF Cup with 205/50R15 tyres. Suspension is stock height and I don't get any rubbing.
(You might with passengers in the rear when pushing it hard - I haven't had it fully loaded.)
at the min im running et35 16'' with 195/45 16 on coilovers and i only get slight rubbing
i used to run 15'' et36 and didnt get hardly any
