Pearce ClioSport Club Member Car 172 cup May 28, 2010 #1 as above looking in to buying some 2118s but dnt no wat offset wud be best for my ff 182 any help wud be great cheers
A Andyman Car Ph1 May 28, 2010 #3 If you can get them to fit et38 would be good as it gets you a wider track. No idea if 182's can take a et38 tho. Ph1 and 2 172's can
172Ben Car BMW M3 Competition May 28, 2010 #4 they come in et38 and et43, et43 i believe are the palmer sport ones, so slightly stronger. Et38 will be closer to O/E
Tom84 Car RB 182 cup May 28, 2010 #5 surely et 43 would be closer seen as standard is et45 i would go et 38 tho they will fit and shouldnt scub if your no too low
P Peperami Car M2 Competition May 28, 2010 #6 Et38 or et43. You want the et43 ones, especially as id assume you intend to lower it/ have some camber with fitting these wheels?
M murcod Car RSC 182 Cup May 30, 2010 #7 I'm running ET37 15x7" rims on my 182 FF Cup with 205/50R15 tyres. Suspension is stock height and I don't get any rubbing. (You might with passengers in the rear when pushing it hard - I haven't had it fully loaded.)
Tom84 Car RB 182 cup May 30, 2010 #8 at the min im running et35 16'' with 195/45 16 on coilovers and i only get slight rubbing i used to run 15'' et36 and didnt get hardly any
