best place for mapping
Car  clio sport 182
i have a 182 standard apart from milltek exhaust and matched inlets,i dont have performance cams but want my car mapped for better performance and fuel eco if possible as since iv put my inlets on it eats fuel,wheres the best place to get this done,and what possible gains can i expect,cheers
FastChip? Do it yourself and save £150?
Im with Lead_Head.
£140 to get the kit delivered. All you then need is a laptop and internet to download the software and the maps you need.
I have done mine and its well worth it! The software also gives diagnostic information, live data as well as a rough BHP and tourque read out.
Save yourself some money and the bonus is you dont have to keep re-paying the garage to update or revert to the orginal map and you can do it yourself!!
sounds good,but how difficult is it to do really,i mean is it just a case of downloading it pluging it into the car and pushing a button to upload it
As far as I know you purchase the kit from www.fastchip.nl
You get a cable you plug in to the laptop, download and install the re-mapping software. Plug in the cable just behind the gearstick, under the compartment in the centre console that slides out.
Back up your existing ECU software and then update with either a 98ron map, a group n map. Just make sure you pick the right .rst and .cal for your particular ECU. They are tweaked from time to time too and release new calibration files to upload to the .rst.
You can also get them to produce a custom map for around £50 specific to the mods on your car.
I'm planning on doing mine once my Warranty runs out :)
Pretty much yes!
The RSTuner is very simple, you just need to make sure that you download the right map for your car. It is advised to take a backup of the original software before uploading a new map but the instructions tell you how to do this.
http://www.fastchip.nl is where you buy them from. Ordered mine on a Thursday and was with me by Tuesday.
There are quite a few threads on here if you search for "RSTuner" for more information. But the general feedback is very good and i am more than pleased with my results.
Why you waiting till your warranty runs out? If you need any work doing under warranty then you can always revert back to the original ECU software if required!
Would they really check the ECU software when doing work under warranty?
i dont know what all this .rst and .cal means tho,so how will i know its right for my car
The file you download has a filename that matches that of your ECU, you really can't go wrong :)
To the other question, after the Warranty coincides with when I should be able to afford it :p
If you go on the website and download the RSTuner Manual. This gives you the information to work out which files you need for your car.
Until you have the RSTuner software and you know which version of software your current ECU is its quite hard to work out which files you need to download.
Yes once you have fixed an error you can clear the codes. Not sure how it can show manifold leaks etc tho?
Just ordered one of these kits. Im seriously confused about all these .rst and .cal files though:S . Cant wait to recieve it. I think i may need some help from someone on here though, hopefully someone in the North West! lol
Andy
Andy
I'd help you but i'm working away at the moment. Its really simple mate just make sure you read the manual a few times and also read the countless threads on here about it. - If i can manage it, it carn't be too hard :)
If you have any questions drop us a PM - we have the same car so the files might be the same too
Andy
Cheers mate. Ive just read through the manual and its a little bit clearer but i think its just the thought of downloading the wrong files or something and fooking up my car:eek: . No doubt ill be dropping you a PM;)
Very Very Interested in this but wouldnt know where to start to be fair.
What sort of gains will this get me anyone ?
Anyone fancy giving us a hand if i get one - few quid in it for themselves
PM me :)
182laney - Im happy to help and only live down the road near Northwich. If you want any help then let me know.
Great:) . Ill drop you a PM. Northwhich is only a few mins away. Ive read through the manual twice now but im still a bit weary. Ill let you know when i get the kit mate.
Thanks, Andy.
Sounds interesting. On a standard Ph2 with just a Ktec panel filter what kind of improvements are likely?
G
