Darryl_1983
RB 182 Cup
I've been tempted by the low boost kits on offer, but i've decided i'm going to stick with the RS2. Partly due to the cost and partly due to the issues several people have had (I know several have had no issues or only minor, etc). I also figured i'd just be better off buying a faster car if i wanted bigger power. Plus i quite like N/A and having the power at the top end of the rev range, just seems wrong shifting before the redline.
So i'm now looking at getting a little more out of the clio without spending silly money and keeping it reliable.
I know the RS2 isn't really that common, so not many will be able to give first hand experience. But having searched the forum i've got a few more questions that are probably easy to answer for a few.
Car is currently running 185bhp, mapped by RS Tuning.
So i'm thinking of adding 197 cams, arp bolts, decat and possibly replacing the exhaust (not sure what brand it is - looks like a k-tec rear and it's got a powerflow middle section welded to the Cat).
My Cambelt is due in 18 months anyway, so it's not really a big deal doing the cambelt early, was thinking of getting it done before the summer next year, April/May time, so only 12 months early. Gives me time to find a 197 camshaft on the cheap hopefully.
Questions:
Is the 197 cam the best option with the RS2 still, i know they need special timing to get the best from them and other cams haven't had expected results from them. These seem like the best option, also hopefully available second hand for £100-150.
When getting the belt changed in the future, can these cams just be locked again like the standard cams. I'm not going to have trouble with timing getting thrown out if someone else does the cambelt?
Best place to get the mapping sorted? EFI or RS Tuning?
Are the ARP bolts easy to install? I'm assuming just need to drop the sump to access them, I'm just thinking about cost involved if i get someone to carry out all the work.
Do i need to replace anything else while the Camshaft is being changed (other than the obvious belt kits)? I'm assuming the dephaser, and everything else remains standard.
I know top end power should be around 195-200bhp with this setup, but what will happen with the torque? anyone got a rolling road print out with similar setup. All the old threads seem to have dead links now.
I'm hoping without the exhaust replacement that i can get this sorted for around £1000 (maybe a touch optimistic? but shouldn't be massively more), so decat, 197 cams, arp bolts, all fitted and mapped. Plan on getting someone to fit the cams, and bolts for me at the same time, so hoping labour will not be massively different to the usual cambelt price
Questions:
