Need to order slider bolts for my front calipers, is there any difference between big redd and grams? Or should I just go for whatever's cheapest?
In fairness the track day was July and I moved to Poland in August. This is the first time I've driven the car since then so I thought it would probably be importantThis has to be a fake post, I can't believe what I'm seeing!
You're actually sorting out your brakes? I'm impressed
Granted, that's only because it's what, 6-7 months since they failed![]()
This, copper slip makes the rubber go soft, I've had issues with this in the past.Just make sure you use silicone grease on them and not copper grease or anything else.
Red rubber grease is the one
Mine have been absolutely spot onIs for seals, but tends to break down in sliders.
Traffic light gp laddoTbf you don't do track days.
Different ballgame with the level of heat they see![]()
