Best thing to remove brake dust
  Arctic 182
Hi all my car has heavy break dust on tried rubbing it off and using iron x but hasn't moved looks like it has set right in any ideas?
Advikaz
Alloy Wheel cleaner, brush it on leave it to do its work.
Failing that I'd probably try polishing it off. I'm sure some of the detailing boys will come along with some superior advice.
TheEvilGiraffe
South East - Essex
Pop a pic up ? Are you sure it's brake dust ?
IronX should remove it, presuming it is actually brake dust ! Bilberry is a safe brake-dust remover too .. IronX should easily remove it though as it's far harsher than billbery.
  Arctic 182
Yea I left the iron x on it and left but no joy
  Arctic 182
I'll get pics up later it's like it's rusted on would hardly come off when used abit of wire wool to try loosening it.the brakes cause a lot of dust been 4 pots and ds2500
  Golf GT & A4 Avant
If it is brake dust, and iron x wont remove it I doubt a wheel cleaner will. Iron X paste is supposed to be a stronger option for localised areas. try a couple more hits with the normal iron x and a bit of aggitation.
Have a quick go with a tar remover also just incase it isn't brake dust.
  Lionel Richie
ring Adam on 01902 439264 i bought it a while ago, so they might not do it anymore, its pink/red and made by Ixtar
If got PF97 dust off my 2118's without blinking when nothing else would touch it!
  182
Fred, that stuff sounds like what i could do with. My turinis and 182 alloys are covered on the inside, would love to completely clean them up. Hows it work? Spray on and agitate, leave it for a while before agitate etc?
Bluebeard
  Whichever has fuel
I use descaling acid or brick acid when i'm presented with rock hard brake dust.
You can buy it in B&Q.
Just don't get it on your skin and be prepared to have very clean brake calipers as well! lol.
Have you tried a tar remover on it yet? a lot of the time people think they have "baked on break dust" they can't shift it quite commonly ends up being small tar spots that have got baked on, thats from our experience anyway with people coming in for advise and alike.
If the iron contamination remover didn't remove it id be surprised if it was brake dust.
