best Value 4 £ upgrade for performance?
  Renault Clio 172 CUP
just wondering in everyones opinion what the best upgrade would be for the clio 172 cup to gain some more power??
k tecs ecu upgrade seems interesting, altho i never like increasing the rev range, renault set it for a reason?
regards to all.
  Clio 172 mk2
Not power mods but suspension & brakes will probably make the most difference for your money.
Ali
  V6, Trackhawk, GTS
Emm...Depends if you can drive.
I'd personally say Suspension and brakes.
But if not go down the engine root.
defo susp and brakes matey i have just had my suspension done and it has completely changed everything about the car and has defo given me more confidence to go in and out of corners faster just got to get the brakes done but unsure and what is a good set uphope this helps mate if not a decat and inlet match is very good on the 172's for sure i think the inlet work is 180 from hillpower and and decat with cost you around 80 and should give you some good gains!!!
thanks all. in my experience best way to upgrade brakes is to change the front calipers for something like four pots, with bigger size disks. that means you can go faster for longer... and out brake all others.
  williams 2
^^ not far off!! lol
some coilovers and uprated brakes wpuld do the trick!!
my opinion leda coily's and willwood or brembo 4 potstoppers!!
On a 172 i would say inlet manifold matching, uprated pads, coilovers or if you dont want to goto expense of coilovers then eibach pro's.
Best performance/pound tho is definately inlet matching
  Valver
Leda coilovers?? you could get a turbo and tb's for that price :p
