biggest brakes
go to 16" & i think it is about 305-308mm disc, but then it would depend on what caliper you had.
/y0z
mach 1 16v, oz superturismos 15, standard caliper, wot caliper could i upgrade to, to accomodate a bigger disc?
[Edited by helplostafingy on 08 July 2005 at 6:36pm]
[Edited by helplostafingy on 08 July 2005 at 6:37pm]
  Fiat Coupe 20v turbo
285mm on 15 inch williams wheels..valver wheels might be a bit tighter though..
285 disks and stock 16V calipers are a tight fit on the Williams and Dynamic alloys you might have 5mm more if you are careful with the calipers brackets.
  2005 Impreza WRX STI
Quote: Originally posted by stu8v on 08 July 2005
315mm discs fit under 15s with motorsport wheels and AP Racing calipers
u sure? my discs are 310mm and i have got 17s on and the caliper is very close to the wheel! cant imagine ap racing calipers to be much smaller than my standard ones?
Its been done, my mate run that setup on his mk 2 Escort.
Quote: Originally posted by helplostafingy on 09 July 2005
So would CP5200 AP Racing 4 pot calipers fit with 315mm discs under OZ Superturismo WRCs?
I can check which calipers he has but they were expensive, circa £1500 each as they have gold plated titaniam pistons. They are gravel spec, ex Mitsi WRC or Scooby WRC i cant remember.
