Billy coilover Rears?
bozothenutter
Technical details : - Bilstein shock absorber Ø52 mm (Bilstein components under Bilstein specifications) - Rod Ø14 mm - Threaded combination adjustable in ride height - Upper and lower plate in high quality aluminum - Spring Ø60 mm specific - stiffness determined according to the application - Hydraulic calibration R.Tec in adequacy with the spring - Helper option or compensator spring depending on the application - High quality ball joint mounting - Mounts with the original fixings Application: rally, circuit, autocross, etc. Not valid for road use. No approval will be provided for this assembly.
https://www.rtec.ws/shop/category/competition-renault-clio-2-38378
