Bilstein B14 with BC racing top mounts?
Wondering if this would be possible? I'm looking for top mounts for my B14 set that are camber/caster adjustable. From what I've read on here is that the AST ones aren't a direct fit. Would the BC racing ones work with the B14s?
My B14s with 54mm spacing don't have slotted holes for camber adjustment and I'm running into an issue where I'm only able to go with about -1.4degrees of camber using camber bolts.
I got my answer from @Kev@KAM through e-mail. So for future references, here's his answer:
They will fit. Theres not a lot of thread at the top so you do have to make sure its done up correctly. You get about 6 turns of the top nut if I remember but a dab of Loctite will help make sure it all stays on.
