bit unsure what to do......
Car  a green 1
going to get an itg panel filter for my 182,
would you leave everything the same and just change the filter or would you,
run a new caf from the airbox to the lower grill,
also would you remove the acoustic valve?
surley leaving everything the same and just replacing the filter would do wouldnt it?
thanks
Just got an ITG for my 172 not long ago. Not done anything apart from fit that so far but the next thing is removing the acoustic valve as I heard it lets more air through with that gone or something, not too sure a CAF is really that necessary in winter though..then again im not mechanically minded at all.
to be honest i dont fancing removing the acoustic valve really, heard it can effect things, ill probs jus replace the filter and leav it at that....
theres enless threads about it, some people are for it and others against it, im just a bit unsure too be honest
Forget the panel,Shotgun. Save up for the Maxogen as you will def feel difference with it. If you do'nt have confidence to fit it, or good toolkit, sweet talk a mate who does. lol
ive been asking for weeks on here if anyones got one for sale and had no reply.......im not paying 390 for a new one
If you replace the airbox with an ITG induction kit then a CAF is a must to be honest. If you simply replace the panel filter in the airbox for an ITG one then a CAF wouldn't really be needed. :)
