looking for some advice i fancy putting black discs front and rear on my 197cup but unsure as to the best kind to get. any suggestions would be much appreciated and does the front and back discs have to the exact same cheers
You do know that the black on the face of the disc, where the pads contact, will get worn off the first time you use them?
It'll only be left in the centre and on the outer rim - and I can't imagine that'll last too long because of the heat.
Personally, can't see that they'd look much different to standard discs - the bits that aren't constantly worn by the pads would just end up covered in brake dust anyway.
arent brembo maxx discs black.... for about 10 minutes, then it goes normal metallic silverblue when bed in, I think the only black left is in the grooves, same with those ebce ultimate discs. but i'd say the brembos would be a good choice.
