Hi criag, how did you spray your badges mate?
Hi mate
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
For the diamond I removed it and used a 2000 grade wet and dry sandpaper (pre soaked in warm water and fairy liquid) to key the surface.
Then I added a coat of white primer and left it to dry overnight; I gently resanded the badge after and added a gloss white paint. I used around 3 coats in total and left that to dry for 24 hours.
Then I used a clear lacquer for the glossy finish; i gave a few thick coats of this to help protect it.
I used the same method for the side bullets but before applying the lacquer I used the nib of a touch-up pen to add colour to the 16v text.
Hopefully that'll give you a rough idea but if you head over to the guides section there's plenty more in-depth threads there
Yeah they do look miles better than the standard Ph2.
Ah right, just thought I'd seen you about Manchester area. Must just be someone else.
Haha yeah that definitely wasn't me!
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
