Quote: Originally posted by cat171 on 25 November 2003
richy,
yeah there is - well its not a design fault, but you can buy a new clutch pedal for it, which is supposed to have eliminated the problem, i got told this when mine went.
i just changed the cable when mine snapped last september, and its still fine.
If its not a design fault - then what is it? Renault realised the problems shortly after the release of both the R19 16v & clio willy / 16v. I think i hold the record for clutch cables on this forum! After finding out about the ped replacment i contacted Renault and got them to fit it. Since then ive had no bother!!
The old design placed too much pressure on the end of the clutch cable, you can see it bend over the top the ped if look. They always snap in the same place. The new design doesnt route the same way - taking pressure away from the end of the cable.
If this is not a design fault - then what is it? I got Renault UK to pay for this work in full after only being told about it after replacing 2 clutch cables already. It should have been a recall if you ask me, watch them go all quite when you ask them.
I did two cables on my old RT before the whole pedal gave way. Luckily I had a friend who works for the AA who repaired it all. He told me later that there was indeed a fault with the ratchet system and that there was a re-call.
Obviously not every one took their cars back though?
So would i get away with taking it back to renault then and getting them to fix the design faulty pedal?????
