Megane Team II F1 R26
Clio has now had a new thermostat, engine coolant flush and it still sits at over 3/4's on the temp gauge.
If i disconnect the temp sensor wire, the gauge drops to zero straight away, so im wondering if its the wrong sensor or wiring somewhere in the loom.
I know the car is not getting to full temp as the new thermostat is rated to open at 89 degrees, and only opens if the car is sat for a good 10mins running.
anyone else had any kind of problem like this?
Im debating if i should put a new sensor (and probably still have the problem) or bypass completely and put a third party temp gauge in.
