Blowers Stopped working but will come on once in a while?
  54 Clio 182 2.0
So my Blowers stopped working about a month ago, and i thought it was that transistor or whatever you call it, but in a morning when i first fire her up occasionally the blowers will work:S I have been told by an electrician that a transistor will either work or not, so im guessing thats not the problem..
Any ideas??
Cheers in advance!
Rob_Willow
  RS MEG, 182
The transistor may not be broken, but if lose i.e. the solder holding it onto the PCB in broken, it will be intermittent. I would start by changing the resister pack. My clio developed a similar problem. Rob
  54 Clio 182 2.0
cheers rob would you advise me to try buy another transistor and fit it in myself according to the guide on here?
Rob_Willow
  RS MEG, 182
I bought one from Maplins, and soldered it onto the board. It worked for 2 days, and then failed. I bought a second hand complete pack off here, which has worked fine since :)
  M3, Cup racer'd 182
I had a simillar problem with my 306 Dturbo i know it's a diffrent car but i guest they all work the same way, anyway turned out that it was a earth problem.
