Blown engine - RS Tuner?
Sss107
  Accord Type R
Hi all, engine has gone bang! I recently done the 98 Ron Map. Driven it for 150 miles and then it went.
Do you think it is possible the Rs Tuner Map could be the reason?
All belts, tensioners etc done in November last year by a specialist. Car has full service history, recent oil change, no fault codes.. Etc
The only thing that has recently been changed is the map. Here's a picture of what we found inside (amongst a lot of other metal debris)
Sss107
  Accord Type R
Here we go.... This was in the 3rd chamber. Looks like part of the valve seating?? No idea what it's called!
Sss107
  Accord Type R
Dropped a valve I take it?
If so I dose happen to these engine's.
Ooooh! Just to say, I have no intentions of slating Rs Tuner. I just found it odd that I just mapped it and then goes after 150 miles!
Is it it likely that it was on its way out (car has 84k) and the map just pushed it over the edge??
Sss107
  Accord Type R
Coincidence and unlucky.
What would cause it to happen mate? Is it a case of just bad luck (cause I have seen 1*2's over 150k with no real issues) or is there preventive maintenance that can be done? I.e uprated valves... - which are horrifically expensive!
My car had full history, regular oil changes etc and not been tracked (to my knowledge)
Scrooge
  E55 AMG
Luck mate. I've seen one with a dropped valve on 50k but I've also seen engines run past 180k with just general maintainace. The valves on these are cheap s**t tbh
davo172
  TCR'd 172
Ran Rs tuner on mine for years no issues ran so much better than std . Just probly on its way before you mapped it.
  RB Clio 182
What causes it to drop a valve tho apart from the obvious?
Surely if you are tootling to the shop at 40mph in 5th it doesn't go bang for no reason?
Sss107
  Accord Type R
Makes me wonder how they survive as track cars! Just checked the price of uprated valves, £458! Oooo
McGherkin
Macca fan boiiiii
Is it the overrun map (pops 'n' bangs) or the normal one?
The overrun map has been known to do such things, but to do it in the space of 150 miles, it'd have to already be on the way out.
Sss107
  Accord Type R
Some engines are weaker than others, my 172 is now on 155k and I give it hell on track/ 'ring but service it regularly etc..and it still makes 174.5bhp (Surrey Rolling Road)
Well I've just bought a 172 cup engine with 60k on it. Hopefully it will be strong enough! I am sure I read that the 172 has a stronger head but might have made that up!
Sss107
  Accord Type R
Was the 98 RON map... I agree, just coincidental I think!
Sss107
  Accord Type R
Little update. New engine is in! Idle is alittle lumpy but that's about it. However..... After getting the car checked out by a Renault Specialist, they confirmed the timing was spot on but injector 2 wasn't right. They cleaned this up but actually made it worse.
Is it complete coincidence that it was number 2 chamber that went and number 2 injector isn't firing as it should. (I used my existing injectors and just swapped the block) Could I have been under fueling and basically cook it? Or running rich and detonate it?! The 98 Ron map pushed it over the edge?. When it went, I had driven it for 150 miles straight so engine would have been hot.
R3k1355
You usually get det from under-fuelling, or bad timing so maybe.
Any signs of det damage on the piston or combustion chamber?
(I realise it might be hard to see det damage when the engine drops and valve and smashed it to f**k inside the engine)
