bogging when cold
  LY 182
got a slight issue with the 182 lump..
when its not up to full operating temperature, if you snap the throttle open it bogs down and will then pick up, will do this everytime you snap the throttle untill its up to full operating temp
i know you dont need to be flooring it from cold before anyone says it, but i want it running right
only fault codes listed are carbon canister but thats not there.
im thinking plugs, as they looked quite old and manky and didnt have the pennies for a new set, gonna try and get some tommorow but anyone had similar faults?
cheers
  LY 182
throttle bodys clean, temp sensor i suppose is a possibilty but it seems to be working ok
on live data the temp increases so all seems well
just weird how its perfect once hot
i've only got the lambda before the cat plugged in too, doubt this would affect it?
  LY 182
its quite bad thought ie floor it and you get no power at all almost like you switch the ignition off for a second then it will missfire and pick up like normal
M
mini-valver
MAP sensor leak? Mine split and did similar but it wasnt temperature dependant.....
  LY 182
its not the map sensor but you have got me thinking
an airleak could give those sort of symptoms i suppose, i have a feeling i may have trapped a plug lead under the plenham im wondering if its not sitting down completely square
will check that when i do the plugs
M
mini-valver
Inlet manifold leak would make it idle really high though...... Unless its hairline I guess??
