bonding carbon fibre panels
anybody handy at cutting and bonding carbon fibre panels? I need some advice on how best to do that and minimise waste given the cost of the panels.
Can i ask why you need to know this?
Remember carbon has shortcomings over some metals like steel, aluminum etc. Once damaged carbon basically loses all its strength, and it snaps opposed to bending. It also loses strength when heated a lot quicker than steel. In the US carbon replacement panels (bonnets, front wings, boots for example) are illegal for road use for these reasons.
-Rob
Rob Carbon is incredible stuff
hence why it is used in the harshest of enviroments and areas.
it may have some small problems but at the end of the day the advantages outweigh them
I know but a lot of people get it for the sake of telling their mates they have carbon bits. Not that im saying this is why Philip has asked the question but Carbon does have some negatives, though yes its strength/lightness is astonishing.
What im saying is if you break carbon you cant repair it, you replace it, and everyone knows how pricey it is.
-Rob
a custom air box that needs the following properties:
1- heat shielding
2- rigid enough at temperature/vibration to maintain a good seal to another surface
3- finally, but not too fussed about 100 grams, lightweight
use polished ally sheet or thermoplastic with reflective tape.
Carbon is a directionally strong material, and they stuff they use for stressed components are typically strong in 2 directions only, plus its not jsut sheet by kevlar honeycombe, several layers of multidirectional fibre and they are now dringing in Z pinning of impact zones.
Pointless unless its for door cards, outer wings, boots and bonnets for weight loss ONLY.....its not strong stuff when used like that.
good points. The airbox design I have in mind would have too many joints etc and if carbon sheets only have tensile strength in 2 dimensions, thats not gonna help. So Ill slightly modify my question. Where can I have an aluminium or thermoplastic airbox design made to my measurements?
james I did a search on pace and they dont seem to do custom jobs. Whats the full name of Baileys, do you have a link or something?
Philip, make sure you make up a cardboard prototype first so that you can guage how it is going to fit. Pain in the ass but a worthwhile exercise especially if you are paying someone to do the job for you. I did this with mine and made up the panels straight from the carboard templates before I welded things together.
excellent piece of advice. How about another one: any ideas on how to verify if the bonnet is shutting tight against my box, i.e tight enough to form a seal? I can obviously design the box to form a tight seal directly off the bonnet, but then how do I know how much clearance I have between the bonnet and other items in the engine bay???
Hi Philip, I actually used a long thick welding rod and bent it to the same profile (inside) the bonnet. If you then place it from bulkhead to slam panel across the engine bay on the rubber sealing strips you can guage the correct height. I must have got it right as I now have a box shape indentation on the felt liner of the bonnet and the bonnet still shuts easily. BTW I used the the same rubber strip along the edges of my box as fitted to the front/back of the engine bay. Have fun ;)
http://www.fifegallery.co.uk/domains/cliosport/coldair02.jpg
http://www.fifegallery.co.uk/domains/cliosport/coldair03.jpg
very impressive work. so you reckon the feed could just as well been through the bonnet vs. the pipe by the battery - obviously that is if you were to make a hole or some louvres in the bonnet. Also noticed the air temp sensor. Good idea, where does that go through the bulkhead? maybe the bonnet release gromet??
Cheers Bondy and philip. If you were "man" enough then louvres or a duct in the bonnet would probably be better. Although I think personally that would spoil the front profile of the car. Also from past experience on another car, in a previous life, I found that the filter was flooded with water during major downpours using this method! I went for the 75mm ducting down to the front grill, similar to what Roamer did ( I actually stole his idea but dont tell him :oops:). To do this you will have to remove the air valve thingy behind the NS headlight. Plug the vacuum hose and detatch and plug in the solenoid to keep the ECU happy. The air temp sensor was only temporary to see if things were working out (cable fed through the passenger door). Results were good with an average intake temp about 2 deg C over ambient. This was tested with about 24 deg C ambient which was rare for Scotland!!
http://www.fifegallery.co.uk/domains/cliosport/coldair01.jpg
Rhys, about £8 for the 1mm steel, about £15 for the Reno rubber seals, £30 for the pipercross 75mm air duct kit, £65 for the heat resistant foil (ouch but nesessary), £20 for paint, gas welder & brazing rods and a good few hours in the garage while the wife was busy watchin Emmerdale, Coronation St and East Enders!! oh and the obligatory cuts and burns during fabrication!
Hehe, nice to see my work doesnt go un-noticed Flying Scotsman :p
Now no trying to copy my current project eh? Kits will come in due course ;)
