Course you wasYeah was going to suggest something similar
Why don't you have a spare wheel in? If it's for weight saving then adding a few kg of plywood to the boot isn't going to help much. May as well just put a spare back in!
Mine's a cup so it didn't come with a spare wheel from the factory. I do have tyre foam though.
I agree though, it wouldn't make much difference in weight if I stuck a bit of ply in there
So they have no spare, but nothing support the cover over the wheel well? - How odd. The Mrs Ibiza has a spare wheel well but it's filled with a plastic insert (with tyre foam, pump etc). Maybe something like that would be better than having to board the boot floor?
I cut some 9mm ply to size and fitted under the carpet
