Will be doing the brakes at the weekend. Want to change the brake fluid. what sequence should i bleed them in? Also anyone recommend me some good brake fluid to use? won't be going on the track so just for road use.
Blees from furthest away from were you fluid resovior/servo is im not 100% but i think rear right then left then front right then left and just normal dot 4 will be good enough for road use
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
