brake bleeding sequence
  Ph1 172
Will be doing the brakes at the weekend. Want to change the brake fluid. what sequence should i bleed them in? Also anyone recommend me some good brake fluid to use? won't be going on the track so just for road use.
Paul
  A3 2.0TFSI QUATTRO
Blees from furthest away from were you fluid resovior/servo is im not 100% but i think rear right then left then front right then left and just normal dot 4 will be good enough for road use
  Audi S3 & 172 Cup
Recommended bleeding sequence as per Haynes Clio manual is:
1. Left front
2. Right front
3. Left rear
4. Right rear
