easy .........unscrew light fitting , this releases complete light fitting .
remove cable connector , remove bulb holder .all bulbs on the other side of bulb holder ,
If you look in the boot behind where the brake light cluster is, you'll see a little black plastic nut thing. Undo this and gently pull out the cluster.
The circuit board holding the bulbs needs to be carefully pulled off the cluster, then fit new bulb and reverse the whole process.
