Brake caliper wind back key?
Car  172Cup
Do I need a "special" wind back key for the pistons? I'll be fitting new pads and discs this weekend (if it stays dry)
How do I wind back the pistons?
Is there a Renault key?
For the rear you can use a thin bar or even a screwdriver to put across the grooves to wind it back in. For the fronts you can use a normal wind back clamp tool or even a g clamp will do as the caliper has a big slot in the middle to get one in.
For the front brakes just leave the old pad in and put a g clamp over to push the piston back. The rears as said above just put a screw driver across and wind back.
If you look in the guide section im sure theres a brake bleeding guide in there. Its a much easier job with two people tbh
make sure you take unscrew the brake fluid cap off first then you can compress the fron calipers with even a bar and just pucsh it in that way if that makes sense
I've always used the air pressure Gunsons Brake Bleed Kit.
Works every time and not expensive!
