Brake/Clutch Pedal Switch
jenic
Since my cruise isnt working i had these off today.
Tested them and the brake switch has 1 n/c and 1 n/o switch on it. Set it so as soon as i tap the pedal lights come on, so seems to be working well.
Is this how it should work with 1 n/c and 1 n/o?
Now the clutch one had 2 of its pins (on the outside) pushed right down, should it be like this? Also couldn't test it since i only have the leads i have been given for work, which are fused and have barely any point, so couldn't get them in. This one also looked a bit worse for wear, and when i forced it so the switch was in all the time cruise still didn't work.
So took a punt and ordered one of these.
Should the clutch one's pins have been like that?
Sorry if its a repost, but i did a search and nothing seems to go into detail enough.
Mike
jenic
Really need help with this now.
I have a new clutch switch, and the break switch has been tested like above, should it be like this or not?
Obviously my cruise is still broken :(
