Brake Fluid/Brake Pads
Car  RenaultSport clio 172 mk2
Hi all
recently my Stop light and my handbrake warning like keep flashing on an off but only when i go round certain bends. It only happens at these certain bends and i have been told its probably the brake fluid and the discs that need changing. Had a look at discs and they do need a change so thats underway but i had a look for the brake fluid bottle and its not where its supposed to be. Is it different to where it says it should be in the manual.
from what i can see i assume its incorporated into the power steering fluid holder. Is this right or is it in a totally different place?
Many thanks
Carl
top left if looking at the engine under the engine cover if u have one, dont put it in the power steering fluid
my dad suggested that it might be incorporated into the power steering fluid, i told him it wouldnt be. Ill have a look under the engine cover
Nope brake fluid is under the engine cover ob the drivers side.
PAS is on the other side of the car.
