Brake Fluid Change. How Much Fluid?
Car  Now Sold :-(
Had my Clio for over two years and the brake fluid has never been changed.
Looking at changing it today so would appreciate it if someone could answer as above.
How much fluid will I need for a full change?
1 litre should be ample , just bleed it through and remove any air . Don't empty the system or it fcuks up the abs .
1l should be enough but I'd say 1.5-2l to be sure if you're doing the one man pedal method.
Cheers for the replies guys. Used just under 1L and was very straight forward.
Used an easy bleed one person gadget. Followed the instructions and all was good.
Wife was a bit miffed when she went to take the kids out and found the stroller missing a wheel. (Used it as it was ideal to set at 20 psi and sit on the engine)
At least you read the instructions. Normally people put those things straight on a tyre with 2.4bar in it and wonders why fluid leaks everywhere!
