I be just bought some pagid standard bads since I have the car nearly 2 months ,and I want to test some standard pads and then try something better like rc5 ...what do you recommend?What pads are you using?
you are talking about the fluid right ?Ok. If you are running pagids then you can run some of the cheaper stuff.
However when you upgrade to CL brakes - because they are a metallic compound theres a bit more heat transfer to the caliper and fluid than a ceramic based pad so you want the best you can.
So you suggest trying something simplier with these pads ?Yes. Your average oem pad will overheat before something like ATE typ200. However the CL are designed to run at extremely high temperatures and usually the fluid becomes the weak point which is why you would need something more top end. For more critical race situations we run thermal backing plates on customer race cars if we think theres a risk of the fluid overheating
Ok guys thanks a lot for the info !!If you are planning on running the CL Brakes RC5 in the next 5 months then Motul RBF660 is about the minimum I would run.
Otherwise go for the cheaper ATE Type200 or SL6 and see how you get on.
