I had an mot yesterday and it failed on load sensing valve seized. Can't find my haynes, and don't know where this valve is???? Any help would be appreciated.
As Fred says You'll see it on the back axle, there will be a spring that won't be returning properly, get it jacked up, and soak the lot in lubricating oil. Work it loads of times, and keep soaking it. After a while you'll hold it, let it go and it'll work better, if need be give it a clean with a wire brush - before you spray it.
