brake pistons
  Golf GTD Mk7
didn't need any pressure on my rears, just turned them. If you're not taking the front calipers off i'd use a hand clamp or something to force in the piston. Make sure to release some pressure though or it won't budge.
  340i
screwdriver for the rear.... they should be pretty easy!
The fronts can be a little stiff, if you fit the outside brake pad.. re-fit the caliper then use the screwdriver to push the piston back in against the brake discs (I found this to be the easiest way for me)..
Remember to remove the brake reservoir cap when you do it ;)
  340i
LOL...
My passenger side caliper was UBER seized, I was dicking around for 15 minutes with it!!!!!!!!!!
