For a number of weeks I've been stumped by a braking problem that is pretty persistent and won't go away. At first the symptoms were of air in the system as the pedal had too much travel but then did stop well at the bottom of the pedal travel.
So far to solve this I've:
Replaced a rear caliper that was past it.
New seals on the Brembos
New discs as one was warped
197 master cylinder
ABS pump
It's been checked over and over for leaks and nothing's been found. The pedal is a little higher but does have too much initial pedal travel for my liking. Anyone had a similar experience or can shed any light on this?
197 master cylinder
ABS pump
