brake sensor and steering column
Car  182
hi all,
car has been in the garage and came up with two faults.
1) brake switch - this was replaced and is still showing up on the faults even when attempted to wipe it comes straight back on. the new switch works fine.
2) steering column (alignment iirc?) - again, won't stayed wiped but the steering seems fine. the wheel isn't at an angle or anything when going straight.
any ideas what might cause this? abs sensor gone? i've had all my discs and pads replaced due to corrosion so could that affect it? and i don't have a clue about the steering column. all seems fine.
any help is welcomed!
cheers
