brakes fitting
remove the 2 caliper bolts.. remove pads, take of cap on fluid resorvoir, use something to lever the piston back into the housing, apply a small amount of coppre grease onto back of pads (non friction material side) and then re-fit. If you've not levered the piston far enough in you wont be able to fit the calipers over the disc.
re-fit calipers and tighten bolts. easy as pie.
