Brakes service?
Steve
Car  LMC10, Puma E
Is it worth having my brakes looked at, ie stripped cleaned & replaced.
Thinking of doing trackday at donno soon & don't want failing brakes.
Donington is hard on brakes, so may be worth having a look to see how your current discs and pads are wearing. If the discs are ok but the pads are getting low then I'd suggest upgrading to Ferodo DS2000 , DS2500 or similar, they still work from cold but retain their braking ability at a higher temperature than the standard pads.
Good quality and clean brake fluid is the key, I would suggest just changing the brake fluid to start with.
