Clio MK2 Ph1
do breathers make a difference
Breathers are used when you change the bend to the throttle body on clios. (usually there's a pipe going from the cam-cover to the bend)
The breather makes sure the oil-damp stays in the cam-housing and not making a mess of your enginebay, but might aswell filter air when air is going into the cam housing. The cam-housing have to breath though. (I guess due to temperature and pressure changes)
cam-housing = engine head???
Anyway I'm not a car mechanic so might be wrong however I like to think I'm not
i think when disconnecting this and putting a breather on there will save you the hassle of cleaning the throttlebody everyonce-inawhile
The oilvapour-s**t that comes out, goes back in the inlet to be burnt (also gucking up your TB). For environmentalreasons, nothing more. They do'nt want it venting into the atmosphere/dripping out onto the road...
get one
