Cheers.
I have turinis with 16mm spacers but would be putting 15" 2118 on so I don't know if they would fit.
They'll fit the turinis I believe. You will struggle with the 2118 depending on their offset. I am running 15 inch Williams wheels which are et35 iirc, and need 16mm spacers and the Brembo Meg calipers have been machined and they only just fit.
I can confirm 100% that the brembos will fit behind cup turinis without spacers on 300mm discs. You'll not be able to run wheel weights on the inside of the wheel though.
Yup..i use my 182 wheels as winter wheel.Will they fit behind standard 16's??
Fit is fine with 10mm spacer.
Cheers.
Iv got brembos 280mm setup behind et38 2118s with a 16mm spacer and there's loads of clearance.
