Brembo 4 pots help needed
Car  Mk1 16v 172 hybrid
Hi just seeing if anyone could help me I have been offered some Brembo 4 pots of a Megan 225 for £130. just want to know what I would need to fit them to my Ph2 172 cup and if you think they are worth it for the price they look in good condition.
Thank Dale
There are a few options for adaptors either 280mm or 300mm .. best part of £170 plus. Then add brembo brake lines, fluids. you might find you need pins and pads etc. Not sure about wheel spacers with 172 cup turinis. Others can advise on those.
Cheers.
I have turinis with 16mm spacers but would be putting 15" 2118 on so I don't know if they would fit.
Cheers.
They'll fit the turinis I believe. You will struggle with the 2118 depending on their offset. I am running 15 inch Williams wheels which are et35 iirc, and need 16mm spacers and the Brembo Meg calipers have been machined and they only just fit.
Thanks for the help think I am going to go for them cheers.
