Is that not overkill for a clio?
Yeah Fiat coupe 20vt's use Brembo's on the front, not sure if they'll fit though (I used to have a 20vt plus ) could also see about getting them from a Focus RS too, again i'm, not sure if they'd fit.This is probably stupid but there must be loads of fiat coup 20vt in the scrappys with brembo calipers as standard, is it possible to use the calipers on a diffrent car?
True, or go for a 'Hi Spec' conversion, they are meant to be good kits.
Really ? I thought that their stuff was rated quite highly. I know of loads of Ford boys (cossies etc) who rate the gear.True, or go for a 'Hi Spec' conversion, they are meant to be good kits.
Careful with Hi Spec stuff......not quite the quality kit that you think.
I fancy trying these, whats everyones opinion??
