Is that not overkill for a clio?
Yeah Fiat coupe 20vt's use Brembo's on the front, not sure if they'll fit though (I used to have a 20vt plusThis is probably stupid but there must be loads of fiat coup 20vt in the scrappys with brembo calipers as standard, is it possible to use the calipers on a diffrent car?
True, or go for a 'Hi Spec' conversion, they are meant to be good kits.
Really ? I thought that their stuff was rated quite highly. I know of loads of Ford boys (cossies etc) who rate the gear.True, or go for a 'Hi Spec' conversion, they are meant to be good kits.
Careful with Hi Spec stuff......not quite the quality kit that you think.
I fancy trying these, whats everyones opinion??
