broke down yesterday??
was sitting at a set of traffic lights then my revs starting increasing till it hit 4k then cut out. couldnt get it started again until about 3 or 4 minutes then i drove it for about 2 hours and no problems atall.
any ideas guys?
thanks
The not starting part sounds like a poss faulty TDC sensor / poor connection... never experienced it causing it to rev up tho.
chaffing?? i thought of the tdc sensor but i was thinking the fuel filter may be clogged as i ran it pretty low yesterday by accident i thought i ran out of fuel at first until i realised i must now have since its happened another 2 times :(
The ECU cover rubs through on the wiring loom..causes alll sorts of problems...EML light on, power loss etc. Also worth checking are the 3 black relays in the engine bay fusebox.. starter relay, injection computer supply relay and cant remember the other 1. Theyre quite common for corrosion on the terminals and causing probs.
