I've just bought some sportlines, I'm assuming I can fit them in the same way as above? With no spring compressors?
I have 2x 2tonne trolley jacks so can do the pair at the back at the same time!
Also with the front springs will I need spring compressors to remove the old and fit the new?? Can you fit them into the strut top without squashing the new spring, so I can do the nuts up again? i.e. with the weight off the front wheels will the springs be totally unloaded?
