buying a clio 182 with a misfire in cylinder 1 cheap , good or bad idea?
  Arctic Blue 182
iam about to buy a clio 182 and the guy selling it has told me the following : EML (engine management light) has recently begun flashing intermittently when car is on idle. The idle is also a bit lumpy/bumpy since this. I dont know whats caused it but a friend of mine plugged in a hand held diagnostics kit which showed up something along the lines of a miss-fire in cylinder one (not personally very mechanically minded im sorry).
i was thinking could it be as easy as changing the plugs/injectors/coil pack? or is it more likely to be the head gasket?
any info would help
regards daniel
Dicky Belly
  Whichever has fuel
It's more likely to be the plugs/coilpack/leads than a headgasket.
It's definitely worth a gamble! (Providing it's cheap enough and the rest of the cars ok)
  Arctic Blue 182
the car is in good condition with only 60,000 miles on it mate , yeah i think its worth a punt if im honest , just wanted someone else's opinion.
Poopensharten
  Golf R
Possible for the following;
Coil pack
HT Lead
Injector
Lambda
Spark Plug
I can almost guarantee it will not be a HG failure, ask any specialist on here and as Dan has said, they are simply unknown to HG failure.
  Ph1 172 & Clio DCi
The amount of 182 Clios I've seen recently with cracked pistons is unbelievable.
Do a compression test before you hand over the cash to be sure.
  Arctic Blue 182
its only done 60,000 miles so i cant see it being the piston, its got fsh and looks like its been looked after! its even got a ktec exhaust on it ;)
  Ph1 172 & Clio DCi
Knackered injectors can kill pistons very easily. It's always the ringlands that go! From the top the piston will look mint!
Poopensharten
  Golf R
No chance thats standard practice. I'm on my third Clio Renault Sport, plenty of abuse and 150k later, no such drama.
  182, SQ7, Trafic
I've just seen the car your on about and become shocked at 182 prices aswell!
It's at £1320 on eBay at the moment and got a couple of other niggly problems, and its not cup packed either.
If it went over £1800 I personally wouldn't bother as your only looking at about £2-2200 for it.
  172
had the same problem pop up on mine with the EML flashing and as Dan at 519 said injector.. as he fixed mine lol
  Arctic Blue 182
its only got a misfire on tickover and the guy just done a 100 mile trip with no troubles , so i wouldn't of thought it was the piston because it would run like s**t if there was a broken ring etc?
  Megane 265 Cup
Did you check the oil/dipstick to make sure there is no coolant mixing with it? That is also a sign of a HG or cracked head etc...
Is the lumpy idle always there when idling or does it go away after it idles for a moment?
Also check the coolant reservoir for signs of oil.
As already suggested get a compression check done and if all of the above are clear it should hopefully be something simple enough to sort out going by my limited car knowledge :)
  Ph1 172 & Clio DCi
No mate! In the engine with the piston with one bit missing, it idled very very slightly lumpy and drive spot on! No smoke nothing! It was just slightly down on power!
  DON'T SEND ME PM'S!!
I've seen a number of pistons with cracked ringlands. Every one of them has also had evidence of detonation on the crown of the piston right above the broken piece. It's crap maps causing issues
  182/RS2/ Turbo/Mk1
It's a lottery with the pistons, they have imperfections and if you are unlucky and that imperfection is on the ring land (small air bubble) its much much more likely to fail.
Bad map seals the deal for sure but isn't always the reason, they do sometimes just go.
as mike says they still drive mint, just slightly down on power, that first piston he put a picture of was from porkies old engine. He tracked it a week before we pulled it apart and it drove mint but was down on power a little, made 185bhp on Surrey rolling road in the morning, then we pulled it apart in the afternoon to find that piston.
most likely cause for OP though is injector, I've seen loads with the same symptoms that have been injectors, but keep driving it like mentioned on this car and you really risk the ring lands as it will make it run lean, in the case of porkies engine it had done an injector on that cylinder only a couple of months before. No co incidence it was same one that failed!
