Buying track car and engine life
As the original thought behind not spending money on belts etc was that if it blows, throw in a cheap used lump, I`m not sure why that option was not chosen.
It seems to me that too much money has been thrown into what was meant to be a bit of cheap fun.
The first time it went he was on the way to get the belts done along with 197 cams fitted.
Both times have been bad luck, nothing more.
If you went with catcam 421 or 428, to get the best you'd fit supertech valves and uprated springs.
With 438's you can use OEM but for peace of mind i'd fit supertech valves also.
That's the way i'd do it.
i never saw the point of supertech valves, the oem ones have been proven good enough across a multitude of builds, that and the fact they are ridiculously expensive
Standard valves are shite and probably the number one killer after aux belt taking out the cambelt.
Plus with cams, 99% of the time you will be raising the rev limit to get the most out of them. In the danger zone for standard valves then.
The standard valves die when they get clouted by the piston because the valves been open at the incorrect time, im pretty sure a supertech valve wouldnt like getting smashed by the piston either and probably bend or worse. I definately wouldnt be getting Supertech valves for a lightly modified cammed engine, or even itbs, only on a very high powered FI build
It's actually the valve head they drop most of the time because they are 2 piece.
£400 is a good insurance for valves IMO.
As someone that IS prepared to learn, and does not have ALL the answers, please expand on 2 piece valves.
I have not encountered these before, possibly as my background is in bike engines, but from what little internet information I can find, they definitely exist.
Fire away please James.
If a pair of valves go together, then it is 99.9% certain that it is due to piston/valve contact, but a single valve of a pair will be a failure for another reason.
I look forward to James reply concerning 2 piece valves.
As far as I know it's so that the head of the valve can be made from a more resistant material and is then welded to the stem. High revs cause vibrations and strain due to the speed they are moving, so they separate at this weld.
Supertech valves are high grade stainless steel for the intake and inconel for exhaust.
Thanks for that.
I have never considered that valves were ever machined from anything other than a single billet.
But before becoming involved with F4R`s, I had not encountered pressed lobe cams either.
Is the reason for constructing a welded valve purely cost?
If you have a 22mm valve with an 8mm stem, you will need to start with a 23mm piece of billet the total length of the valve, but if welded, two pieces of billet of vastly different O/D dimensions?
Looking at JB21`s singe valve failure, the stem is clearly visable in the valve guide.
Have you any feedback on Sinus valves v Supertech?
I keep reading that engines are cheap - but whenever i look, the only cheap ones are the ones with cambelts snapped and therefore probably just as knackered as the one you're replacing.
The running engine seems to be £500 odd, then add on the price of belts, its not exactly cheap.
Not to mention the ball ache of shipping, and fitment.
Left standard, but well maintained, they go on forever, fingers crossed
500 for a performance model engine is dirt cheap.
Thanks for that.
Yeah just a cost thing really.
Not heard of Sinus valves, but the supertech are rated by most of the top engine builders for these engines.
standard valves are two piece friction welded afik very close to the head supertec are done higher up away from the head of the valve.
re phil's i'm 99% certain it dropped a valve seat not the head of the valve but the seat killed the valve. i've opened three f4r engines that have dropped a valve head, all have been pretty much 7,000rpm or higher at the time of failure and have just about destroyed the crown of the piston. all had the seat intact and the pictures of a few others i've seen had seats intact.
it did actually throw me at first when i lifted the upper inlet and there was a piece of the seat that had dropped out of the breather hole and was sitting on the plate. took me a few minutes to work out it was a piece of the seat.
Thanks, i was aware of that.
Mine was £240 delivered lol. If that's not cheap I dunno what is
Mine has been sound for 4/5 days a year for the last few years, I am fairly anal with fluid changes etc though and I dont drive it within an inch of its life but still drive it hard, purely as I would like it to last and I have to drive it home.
Just shorten engine oil interval or/and add oil cooler. Still much less cheaper than trouble with getting new engine..
