C Spanner
Car  H&R + Pole Position'd Cup
Is there anything else that can be used instead of a c spanner to adjust H&R coilies?
can i ask why you wouldnt use the c spanners?
would be a bit dodgy but you could turn them with a soft ended rod/bar and tap it around with a hammer. would realy advise it, no reason why c spanners wouldnt work?
I don't have any C spanners yet :)
Not to worry, I'll leave them as they are for the time being!
Clean them off with some citrus degreaser and a brush first, the adjuster rings and the threads.
That way you wont have to put as much force on the c spanner slots if you use a hammer and punch.
