I believe you should still be able to export a dxf as a sketch rather than the 3D.
If you need a 3D dxf feel free to ping me a .step file and I’ll convert it on AutoCAD.
Hi mate, thanks for your reply.
You are indeed correct - it seems I can export the 2D sketch as a DXF file. I wasn't aware I could do this directly from the sketch (I was trying to use the File-Export menu option, which is greyed out for non-subscription users). Thank you. As far as I am aware, this is all I need for now.
However, if it turns out that I need a 3D DXF then I'll give you a shout. Thanks again
DXF is for 2D really, in Solidworks I export DXF from the drawing not from the part (although technically you can do either).
If you cannot export to DXF what file formats can you export to? IGES, STEP?
If yes to any of the above send it over and I can export DXF files for you
*EDIT Sorry didn't see the other offers of conversion help, you seem well covered
from google
"The only DXF support in Fusion is 2D, via sketch import and export."
Hi Rob, likewise - thank you for your kind offer of help.
Yes, I always thought that DXF was more oriented towards 2D/planar type schematics rather than for 3D realisation. As the aim is to ultimately cut the shapes from 5mm aluminium (or possibly some other metal) my thinking is that the 2D DXF will be sufficient.
In terms of exporting from Fusion 360, I can export to:
- Autodesk Fusion 360 Archive Files (*.f3d)
- 3MF Files (*.3mf)
- Autodesk Inventor 2021 Files (*.ipt)
- FBX Files (*.fbx)
- OBJ Files (*.obj)
- SketchUp Files (*.skp)
- SMT Files (*.smt)
- STEP Files (*.stp, *.step)
- STL Files (*.stl)
- USD Files (*.usdz)
The following are only available to subscription holders (i.e., not me!):
- DWG Files (*.dwg)
- DXF Files (*.dxf)
- IGES Files (*.igs, *.iges)
- SAT Files (*.sat)
My confusion comes from my unfamiliarity with Fusion 360, and more so the fact that I
cannot File-Export to DXF but I
can directly right-click on the sketch in the object browser and "Save as DXF" that way... (as
@Archtronics pointed out). I'm not really familiar with some of those file formats.
I do, however, recognise FBX, OBJ, STL and USD - as these tend to be used in the sort of 3D work I'm involved with in terms of 3D CGI for games/movies and visual effects. They aren't particularly well-suited to CAD/CAM though.
PS what are they for? Shapes look cool.
My understanding is that they form the basis of customised bracketing to stabilise/mount a motorcycle engine (or related to something like that). Once cut, they will be shaped, tweaked and drilled by hand to suit. That's all I know!
Again, thanks to both of you gents for the replies.
If I need further help I'll give you a shout.
