Caliper bolt tool?
  www.renparts.co.uk
What tool is it i need for removal of calipers on my 1.4 16v? is it a torx bit? if so what size. Can't seem to find one the right size.... and where can i order online?
thanks
josh
  www.renparts.co.uk
like i said a bit.... IE one that fits in a hole that has 6 sides... not one that fits round the piece of hardware in question.... which would be a socket. My local garage told me its a torx bit but i can't seem to find one the right size for sale on its own only in sets..
  Lionel Richie
get me a pic, i have no idea what you're on about
i've NEVER seen what you're talking about and i've worked on a shitload of clios
  clio 200 F4Rt
i mean Hex key....
which is how most callipers that i have come in contact with are attatched to the strut
  2.0 175dci rs meggy
he means the two bolts directly behind the piston - not the teo 13mm bolts that hold the caliper to the carrier
like the two bolts in the pic??? but obviously the caliper is seperated
  www.renparts.co.uk
Im aiming for the wrong items to change the pads? thats what im reffering to...
  C63 AMG, F430 & 172
to change the pads u should only need to remove the 2 13mm bolts on the back of the caliper and just push the piston back then fit the pads then bolt the carrier on
