Barron
Turbo S,Exige,R5,182
Right as some of you may know i have bought a 02 plate Clio 172 with a fucked engine. I also have an engine which has only covered 16k miles.
For peace of mind im going to do a full service including Cam and Aux belts while the engine is out of the car.
So far ive got:
7701476675 - Cambelt Kit
7701477519 - Aux Belt Kit
7700106271 - Plug 1
7700274026 - Plug 2
??????????? - Water Pump
??????????? - Water pump gasket?
??????????? - Inlet Manifold Gasket
??????????? - Inlet 'O' Ring
??????????? - Exhaust Manifold Gasket
i will also be doing the typical of changing brakes/oil etc.
Have i missed anything?
If you could fill in the gaps with the part numbers that would be fantastic
thanks alot
carl
So far ive got:
7700106271 - Plug 1
7700274026 - Plug 2
thanks alot
carl
