Cam Belt change, Key or Tapered Shaft??????
  Fiesta ST-3
Hey all,
Just need to know if the bottom cambelt sprocket/pully coming off the crank shaft has a key to slot into a key way to align and lock the shaft and sprocket or is it a tapered shaft???
Scott
Gez
  Yozza'd 182 RB 188bhp
tapered shaft mate. need a locking pin that goes in the front of the block
  Fiesta ST-3
Sorry no on the phase 1 172? Just taken mine off to re do the csm belt and there was no key present and aint sure if there was meant to be one?
  Fiesta ST-3
Yes locked the crank, but took the bottom pulley off snd there is nothing in the key way? surley then the pulley will just slip?
M
mini-valver
Pin through the TDC hole in the block, cam locking tool behind the 2 black caps....
  Fiesta ST-3
Thanks for the help chaps. Changed the belt and tensioners and water pump. So much easier when the engine is out of the car.
  Fiesta ST-3
Just one last quick question, the gasket on top of the head and under the inlet manifold, does it have a gasket or just liquid seal? As if its a gasket, going to replace it!!
  ITB'd MK1
between the rocker cover and the plenum? there's a teardrop shaped rubber gasket. if you mean for the rocker cover to the head.....cams out, and it's liquid gasket
